Author Topic: Replacement Liquid Line between Condenser and Evaporator  (Read 9151 times)
Offline ehjorten
« on: June 26, 2018, 01:33:29 pm »
Since nobody makes a replacement line besides the Suburban one with the Rear A/C port, I decided to make up my own!  I found that Vintage Air sells their "U-Bend-Em" line of straight tubes with the proper swaged o-ring ends on them.  I ordered some to recreate my stock liquid line that was crusty and damaged and also did not fit to the replacement "stock" condenser.
Here is my mock-up:
Any tips for successfully brazing 0.049" wall aluminum tube?!  I keep blowing a hole through my trial sections of tube with my MAP-gas torch!  I do get it brazed, but a hole in your line isn't going to work very well!
« Last Edit: June 27, 2018, 02:03:54 pm by ehjorten »
-Erik-
Offline ehjorten
Re: Replacement Liquid Line between Condenser and Evaporator
« Reply #1 on: July 02, 2018, 08:47:38 am »
Broke down and got my liquid line TIG welded.  Pressurized it and submerged underwater to ensure it was air-tight before installing.
Here is the old and the new!
And here is the new line installed on the truck!
« Last Edit: July 02, 2018, 02:44:43 pm by ehjorten »
-Erik-
« Reply #2 on: July 02, 2018, 09:47:46 am »
Pics aren't displaying.
Offline ehjorten
« Reply #3 on: July 02, 2018, 11:03:22 am »
How about now BD?  I forgot to put those pictures in my shared album.
-Erik-
« Reply #4 on: July 02, 2018, 11:14:40 am »
Perfect.  Looks sharp!
Offline ehjorten
« Reply #5 on: July 02, 2018, 12:12:38 pm »
copied the wrong install picture.  Fixed!
-Erik-
« Reply #6 on: July 02, 2018, 02:17:18 pm »
The "Fixed" pic is not displaying.
Offline ehjorten
« Reply #7 on: July 02, 2018, 02:43:27 pm »
Argh...technology!  ;D
-Erik-
Offline topp
« Reply #8 on: July 05, 2018, 06:57:46 pm »
Rock auto sells them I think, but good job on those
Sent from my SM-G955U using Tapatalk
'90 Suburban TBI 350
Offline ehjorten
« Reply #9 on: July 06, 2018, 08:30:18 am »
AC Delco only makes the Suburban one with the extra Rear A/C Port.  The one without Rear A/C is disco'ed and not even VPI has stock.  There are some Rear A/C Block off kits that give you a machined slug of aluminum, an o-ring, and a nut to block off the rear port, but I wanted something that didn't have that extra port.  I have also found that for whatever reason, be it a combination of OE and Aftermarket parts, but my original line did not align with my new condenser at all!
I didn't take the AC Delco 15568999 out of it's packaging from RockAuto to see if it fit or not, as I wanted to be able to freely return it.  AC Delco 15568998 is the one without the Rear A/C port, but it is no longer available.
« Last Edit: July 06, 2018, 08:32:23 am by ehjorten »
-Erik-
