Author Topic: Front Brake Rotors / Hub Assembly  (Read 4892 times)
Offline Jon87V20
« on: July 05, 2018, 06:08:18 pm »
Hi, Everyone:
I'm trying to replace the front brake rotors on my '87 Suburban V20 with a 5.7L. When I picked up some new rotors from Autozone, I didn't realize you need to press the hub assembly into the new rotors. I don't have access to a press at this time.  When I picked these rotors up, there was two applications to choose from:
"With front locking hubs secured with small bolts" and
"With front locking hubs secured with a snap ring"
Mine has the small bolts equipped.
There's also a third choice listed where it comes with the new rotor and hub assembly already joined. However, they only have one of these for the hub secured with snap ring.
I ended up looking at Oreilly's as I need a complete hub and rotor assembly for the bolts type.
Oreilly's doesn't specify which application theirs is for. Here's the part no. for the one I'm looking at: 56287RGS. Can anyone tell me if this will fit, or any other part numbers I can look at etc.?
It says compatible with "V20 Suburban 4WD Silverado with engine V8 - 5.7L 350ci GAS TBI vin K - 2 valve OHV" in the details so it seems like it should?
Thanks!
1987 Chevrolet Suburban V20 Silverado
350ci TBI TH400 NP208
Re: Front Brake Rotors / Hub Assembly
« Reply #1 on: July 07, 2018, 02:59:09 pm »
i know its been a couple days but that one you posted does appear to be the right one for your truck
Offline Jon87V20
« Reply #2 on: July 07, 2018, 05:12:20 pm »
Ok. Thanks, Irish!
Offline MIKE S
  • Member
« Reply #3 on: July 09, 2018, 05:38:44 pm »
OEM# is 14026767. that# crosses to the # you found at O reillys.
