Author Topic: Won’t go into gear  (Read 3621 times)
Offline c10rider
Won’t go into gear
« on: July 18, 2018, 02:21:43 pm »
I have a 74 c10 and I changed the shift shaft seal , I had to pull out the shifter to get it out because I stripped the seal with the tool that I bought to pull it out with, well I got it all back together and now it won’t go into gear so I dropped the pan again and made sure everything was back the way it’s supposed to be and it was , well before I put the pan back on I wanna make sure that I there isn’t another cause that could be addressed before I install the pan back on , can someone please advise me to check other possible problems, and also my accumulator cover is leaking I’m going to change the o-ring before I put the pan back on , I’m not very good at mechanics but you tube videos sure help
Re: Won’t go into gear
« Reply #1 on: July 18, 2018, 03:56:07 pm »
cant really help you out but what transmission you working on?
Offline c10rider
« Reply #2 on: July 18, 2018, 03:58:37 pm »
T350
Online bd
« Reply #3 on: July 18, 2018, 04:20:00 pm »
Make sure that the manual valve moves freely and that the S-link connects the valve to the gear selector linkage.  Verify that the external shift linkage is correctly indexed and timed between the shift lever on the column and the gear detents inside the transmission.  Make sure the transmission is appropriately filled with fluid.
Online Rapid Roy
  • Euless, Texas
« Reply #4 on: July 18, 2018, 04:52:03 pm »
Welcome to the site.
Mopar by Birth
Chevy by Choice
Offline c10rider
« Reply #5 on: July 18, 2018, 06:09:15 pm »
Thank you sir will do
