Author Topic: JEGS GM Rear Disc Conversion Kit for 259?  (Read 5072 times)
Offline Ctdexp
« on: July 23, 2018, 08:24:59 pm »
Greetings,
   I have looked high and low to find more details about this Jegs GM rear disc conversion kit. I even emailed Jeg's with zero help other then they say it will not fit.
Link
https://www.jegs.com/i/JEGS/555/631027/10002/-1?trk_msg=R0KOU4B0IKL4FDL2FVCE5RAUO0&trk_contact=JOV4TMJGEKCU3G37RVL5P25ENK&trk_module=pda&trk_sid=1GMK610FGEL2P1V0EGU4Q13938&utm_source=listrak&utm_medium=email&utm_term=CHECK+OUT+THE+NEW+PRICE&utm_campaign=Price+Drop+Alerts&utm_content=Message1
It is by far the cheapest and looks complete rear conversion system out there. I just do not see why it would not fit.
I wondered if the caliper mounting brackets would be the wrong bolt pattern size or something.  Looking at my truck and the kit I do not see why it would not fit.
Has anyone bought this kit before and installed it?
I am almost tempted to buy the kit and even if it does not work, simply by the brackets from Captain and use it.
Thanks, I am new to the forum. I have had a mess of square bodys and really like them. Love this forum, just shame it took me forever to find it....
Offline Ctdexp
Re: JEGS GM Rear Disc Conversion Kit for 259?
« Reply #1 on: July 23, 2018, 08:29:26 pm »
UGH...why does this happen once I ask for help, I am able to find my own answer...Add that to Murphy's law.
 "The included rotors are 11.14" with 2.786" hub I.D. and holes for 5 x 4.5" BP utilizing 1/2" studs and 5 x 4.75" BP utilizing 7/16" studs."
So the rotors are the wrong bolt pattern.....
Online Rapid Roy
  • Euless, Texas
« Reply #2 on: July 23, 2018, 09:49:43 pm »
Welcome.
Mopar by Birth
Chevy by Choice
Offline Ronno6
  • Elder Student
« Reply #3 on: July 23, 2018, 10:23:22 pm »
Also, depending on your truck, the Jegs setup will not work with staggered shocks.
The shock interferes with the caliper on the trailing side of the axle housing.
You can lead a man to water, but yoiu can't keep him from pissing in it.
