Author Topic: Power door lock issue  (Read 3518 times)
Offline jpatters13
    • 74' Chevy Truck Project
« on: August 13, 2018, 08:49:37 am »
I stripped an 86 C10 of its power locks and windows and put them in my 74 C10.  Everything works except the driver door lock switch will only lock the doors and the passenger switch will only unlock them. But neither switch does both.  Any advice?  Could it be the lock relay on the firewall? They are about $60 to replace but I want to make sure that is the problem before I do it.
84 Silverado K10
74 Custom Deluxe C10
Re: Power door lock issue
« Reply #1 on: August 14, 2018, 10:38:36 pm »
Power Locks
Check the wire connections to both door switches and to the relay.  Use a test light to verify power to both door switches via the orange/black wires.  Then check for continuity through each switch while actuating lock (light blue) and unlock (black/white).  If there is continuity through the switches, check for power delivery to the relay on the light blue (lock) and black/white (unlock) while operating the door switches.
