Author Topic: Wheel lock up  (Read 4543 times)
Offline battleslayer
Wheel lock up
« on: August 25, 2018, 02:44:48 pm »
I'm sure this has been posted before but, my patience is lacking. I own a 1978 Chevy Silverado C20 camper special. I have a GM 14-bolt rear end. A couple years ago I converted the peg leg to a Eaton truetrac limited slip. I still have the drum brakes. In the eight years I've owned this truck it has not had the emergency brake cable from the pedal back. The problem I have is lately the right rear brake locks up when I'm almost coming to a complete stop and when I come to a complete stop. It does not happen in reverse . I first put it in drive after starting it, it feels like the brake is applied. Then I put it in reverse and go back a few feet and put it back in drive I have no problem. I have not pulled the rear drum off yet . I'm assuming I'm not the only person to have this problem. So any help will be greatly appreciated.
Offline Rapid Roy
  • Euless, Texas
Re: Wheel lock up
« Reply #1 on: August 25, 2018, 04:22:17 pm »
Welcome
Mopar by Birth
Chevy by Choice
Re: Wheel lock up
« Reply #2 on: August 25, 2018, 05:09:59 pm »
Look for gear lube at the bottom of the backing plate.  Gear lubed soaked brake shoes will grab like you are describing
Re: Wheel lock up
« Reply #3 on: August 25, 2018, 09:49:43 pm »
Thank you. I will check it in the morning. It's night time here in vegas. Not to sound stupid but, with the pads wet, wouldn't it do it in both directions?
