Author Topic: Junctin Box connections  (Read 3838 times)
Offline Will B
« on: August 30, 2018, 02:20:52 pm »
How do I remove the wiring harness plugs on the engine bay side of the junction box? Running a new intermediate wiring harness and cant get the old one off because I cant get the tabs or whatever off that hold it down. Truck is an 83 K20.
« Last Edit: August 30, 2018, 02:22:42 pm by Will B »
Re: Junctin Box connections
« Reply #1 on: August 30, 2018, 04:04:54 pm »
Are you referring to the bulkhead connector located to the left of the steering column?  Unthread the center bolt that retains the engine harness connector to the firewall bulkhead plug.  As you back the center screw out it should dislodge the connectors so that you can separate them from the firewall.  Once the harness and connectors are dangling loose, the paired halves will slide apart and separate from one another.
Offline Will B
« Reply #2 on: August 31, 2018, 08:18:19 am »
Perfect, thank you!
