Author Topic: Bully step up  (Read 5645 times)
Offline Smitty31
  • 1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
Bully step up
« on: September 01, 2018, 02:21:14 pm »
Ordered the bully step up bars for my 79 k10. Has anyone used these? They mount to the back side of the rocker panel. Has anyone had good luck with them or any bad luck? Thanks
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
Offline Smitty31
Re: Bully step up
« Reply #1 on: September 01, 2018, 02:23:49 pm »
Here is a pick of them
Offline Smitty31
Re: Bully step up
« Reply #2 on: September 01, 2018, 02:24:49 pm »
Oh i dont go off road or 4 wheeling. My wife is 5 ft 3 so she need help to get in the cab lol
Offline 75gmck25
Re: Bully step up
« Reply #3 on: September 04, 2018, 07:41:25 am »
Because there is no truck frame outboard of the gas tank, these steps bolt to the flat vertical piece at the bottom of the cab.  It seems a little flimsy, but mine have been on for at least 10-12 years, and they are still fine.  I did have an issue when my son took it mudding because the mud pushed up on the step and that push in the wrong direction loosened everything up, but it went back together fine.
When you bolt it to the cab there is very little space between the cab and the gas tank to fit the bracket and bolts. I think I had to experiment a little to get a bolt that was exactly the right length.
Buce
Re: Bully step up
« Reply #4 on: September 04, 2018, 08:03:28 am »
ive never used these so take it with a grain of salt. but the rockers are a know rust issue on our trucks, normally the first place to rust out. i wouldnt want to attach something that might speed this process up or even allow someones body weight to twist it.
Offline ehjorten
Re: Bully step up
« Reply #5 on: September 07, 2018, 08:36:31 am »
Have them on my 1977 K20.  They were on the truck when I bought it and are still there!  I use them all of the time and I don't perceive any flex when stepping up on them.  I am 6' - 210 lb.  I have owned the truck for about 18 years.
-Erik-
Offline K-10 red
Re: Bully step up
« Reply #6 on: September 07, 2018, 07:45:01 pm »
I've had them bout 12 years on my 1985 K10  LWB no problems.
Offline Smitty31
Re: Bully step up
« Reply #7 on: September 13, 2018, 11:34:51 am »
Thanks guys
Offline Rapid Roy
  • Euless, Texas
Re: Bully step up
« Reply #8 on: September 13, 2018, 01:35:01 pm »
After install, please report back with pics and your results. Curious to see the outcome.
Mopar by Birth
Chevy by Choice
