Author Topic: Bad booster? Replaced master, no power brakes, vacuum leak  (Read 4934 times)
Offline Junkie
« on: September 02, 2018, 02:28:09 pm »
A couple weeks ago my master went bad and started pushing fluid from the front reservoir to the rear. This morning I replaced the master, only to find that I don't have power brakes.
I noticed a hissing, pinched the hose from check valve to booster and hissing stops/idle drops.
Is there any chance I could have bumped something that I need to fix, or do I need a new booster?
1973 C20, 350/350
Re: Bad booster? Replaced master, no power brakes, vacuum leak
« Reply #1 on: September 02, 2018, 03:16:35 pm »
If the 11/32" vacuum hose is not perforated and the check valve grommet is not torn and the check valve is not cracked/broken, replace the booster.  It probably has a torn diaphragm.
Offline Junkie
« Reply #2 on: September 02, 2018, 03:18:29 pm »
is there anything I should know about replacing a booster? never had one off before
when I pinch the line between the check valve and the booster the hissing stops, so I'm pretty sure it isn't the check valve
should I replace the check valve anyway?
1973 C20, 350/350
« Reply #3 on: September 02, 2018, 11:18:41 pm »
The check valve is located on the booster.  The vacuum hose runs between the intake manifold and the check valve.  Post the year, make, model and a pic of what you are working on.
