Author Topic: '85 C10 Recommend tire size, stock height and rim, LS swap  (Read 19832 times)
Offline dogfacedsoldier
  • Tax Eater
« on: September 14, 2018, 08:12:05 am »
I have a 1985 C10, 8' bed.  Stock height, stock 8" rally wheels.  I like the stock rims and height.  2WD.
I have an LS6 cammed LQ4 6.0 dropped in it, and regeared with 3.73.
I am looking for a recommendation for optional tire size.  My goal of my vehicle is to be a truck that is a sleeper, not a drag car that looks like a truck.... if that makes any sense.
Thank you!
Re: '85 C10 Recommend tire size, stock height and rim, LS swap
« Reply #1 on: September 14, 2018, 08:19:09 am »
255 70R15 is slightly taller that stock, fit the 8" rims well.  To me the perfect tire size for stock rims riding at stock height
  • Tax Eater
« Reply #2 on: September 14, 2018, 08:38:37 am »
Thank you for the input zieg85.  Greatly appreciated. That is right in the middle of what I have been kicking around.
My truck currently has 275/60R15 BFGs in the rear, and 255/60R15 BFGs in the front.  I cannot stand the smaller tires up front... but that was what was on the truck when I bought it.  There is plenty of clearance for the 275/R15s in the rear, I'm relatively content that I can put the same up front... but I would like to try a little taller, or am I pushing it?
I have a set of 235/75R15 Michelin Defender LXT tires that I kept off of my 1990 F150, with only 15K miles on them (80K tires).  I would be interesting in using these, but would like something wider.
« Reply #3 on: September 14, 2018, 09:48:25 am »
235's look fine and Michelin tends to be wider than most.  Here is 235's on the same truck but with 7" rims
  • Tax Eater
« Reply #4 on: September 14, 2018, 10:57:07 am »
Excellent, I will go that route.  I still tuning the LS, the taller tires will work in my favor.
This is how mine sits now... hate the smaller tires up front!
  • Tax Eater
« Reply #5 on: September 14, 2018, 11:01:08 am »
Double post...
« Last Edit: September 14, 2018, 11:52:02 am by dogfacedsoldier »
« Reply #6 on: September 14, 2018, 12:52:29 pm »
I never do 60's on front but I see what you mean about tire height.  Mine was a 84 4.1L 3 on the tree with a 2.73 out back.  You couldn't be in a hurry to do anything but once it was wound out, it cruised 75 perfectly and got 17 mpg with a topper on it
  • Tax Eater
« Reply #7 on: October 02, 2018, 11:35:36 am »
235/75R15 Michelin Defender LXT tires all around
Much better.  Looks like a truck again.
