Author Topic: Installed new u joints and there very tight  (Read 7127 times)
Offline c10rider
« on: September 24, 2018, 02:47:13 pm »
Hi everyone I have a 74 c10 and I installed the U joints and they feel very tight I was wondering if I should shave down the clips to loosen them up or should I leave them tight , I took out the new u joint thinking that a needle bearing had fallen to the bottom but the bearings were in tact so I bought another one and installed it and it’s also tight , someone told me that they will loosen up , I’d like more opinions please thank you
Offline c10rider
Re: Installed new u joints and there very tight
« Reply #1 on: September 24, 2018, 02:58:04 pm »
Sorry I thought the first post didn’t go through
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: September 24, 2018, 02:59:42 pm »
I take it that they do move, right?
They will loosen up, make sure you grease them well, and re-grease them in soon.
1980 C-10 under construction
Online bd
« Reply #3 on: September 24, 2018, 03:22:15 pm »
Assuming you installed the correct u-joint, chances are that the yoke(s) slightly collapsed during installation of the u-joint cups.  If that is the case, you can relieve the binding by driving the yokes outward (away from the u-joint) using a long taper punch and hammer.  One or two firm whacks should be sufficient.  Be careful to position the punch so that it doesn't crack or deform the cups or the yoke.
« Last Edit: September 24, 2018, 03:24:28 pm by bd »
Offline c10rider
« Reply #4 on: September 24, 2018, 04:24:20 pm »
There stiff but they do move thanks guys for the info
