Author Topic: Stiff TBI throttle pedal  (Read 3741 times)
Offline Jerr-conn
  • Retired tool maker
« on: October 07, 2018, 11:10:14 am »
My 87/350/700r4/TBI engine had a stiff pedal. So I replaced the cable assy with new. Greased before installing. Still stiff. Very touchy when applying initial pressure. Why is it so touchy to
Accelerate only? No extra added spring or anything else.     Thanks.
Jerry
Online bd
Re: Stiff TBI throttle pedal
« Reply #1 on: October 07, 2018, 11:17:30 am »
Check for radial play in the TBI throttle shaft.  The throttle plates may be catching in their bores.
Offline Jerr-conn
« Reply #2 on: October 08, 2018, 07:43:17 am »
Drove it yesterday for first time since fusible link issue. Seems better. Not sure why.
But I will check throttle play this week. Thanks Rich.
Jerry
Offline MIKE S
  • Member
« Reply #3 on: October 08, 2018, 10:27:24 am »
Your TV cable going to transmission could also be worn causing binding. Disconnect cable to transmission and try it. Don't drive it with cable disconnected. Can burn up transmission in a little as a mile.
