Author Topic: Transmission question  (Read 4616 times)
Offline ssdents
« on: October 07, 2018, 11:09:10 pm »
I bought an '82 short bed a couple weeks ago. Previous owner said it's a 383 stroker with 3.73 gears. I don't want to change either characteristics, but I want to be able to take advantage of them and be able to run on the highway at a relatively low rpm. What transmission should I look at? Some have said a 4l80e, but the current setup is not electronic. Is there a non-electric version? Pardon my ignorance. Transmissions have always confused me.
Re: Transmission question
« Reply #1 on: October 08, 2018, 12:50:13 am »
700r4 is the only one you can go with without a computer from GM. you can have it built up to handle the 383
Offline Rapid Roy
  • Euless, Texas
« Reply #2 on: October 08, 2018, 06:19:17 am »
Welcome.
Mopar by Birth
Chevy by Choice
« Reply #3 on: October 08, 2018, 06:01:16 pm »
Second what Irish said.
Offline Stewart G Griffin
« Reply #4 on: October 08, 2018, 09:11:18 pm »
Can you take a pic of the pan?
Offline 75gmck25
« Reply #5 on: October 09, 2018, 07:03:57 am »
You can buy an external controller to run the 4L80 or a 4L65 without the stock computer, but it looks like the typical price is about $600 for the controller.  It would probably be cheaper to have a 700R4 rebuilt to specs that would hold up to the power of the 383 stroker.
Bruce
« Reply #6 on: October 09, 2018, 09:25:04 am »
i have a "black box" on my cummins/4l80e. it was i think 300, some say its a "bad" setup because it runs full line pressure. the only con i see is that it made an automatic trans into a manual
Offline ssdents
« Reply #7 on: October 10, 2018, 09:58:02 pm »
Thank you for the help.
