Author Topic: u joint question  (Read 6484 times)
Offline jcondo
u joint question
« on: October 08, 2018, 06:54:04 pm »
Did they use 2 different u joints on the front axle in 77 K10?
passenger side went together just fine with a 371 u joint, but the driver side wont go flush and wont slide into the hub casing if they are not flush.
Thanks for any info.
Re: u joint question
« Reply #1 on: October 10, 2018, 10:45:07 pm »
Are we talking the inner to outer shafts U-joints.  They "should" match.
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: December 25, 2018, 06:06:50 pm »
They were the same on my '78.
Check the build date; was it on a Friday after 3pm? Those '70's were wild! :>)
1980 C-10 under construction
