Author Topic: 86' C10 intermittent starting issue  (Read 3644 times)
Offline jricharc
« on: October 09, 2018, 01:04:46 pm »
So I have an 86' C10 that has had a 350 installed in place of the original V6.  When I got it it had starting issues so I replaced the entire distributor and everything was running great. So this weekend I ran around and picked up some tile and drove it home and parked it, the next day I went to start it and it just cranked but wouldn't fire.  It was getting fuel so I assumed it was a spark issue so I looked for any loose wires and checked the distributor cap and everything looked fine so I let it sit until I could get some help. The next day I wanted to check for spark and pulled a plug wire off and told my wife to crank it and it fired right up, could I have moved a wire somewhere that was loose or grounding out causing it to not fire?  What wires should I check to look for any issues?
Re: 86' C10 intermittent starting issue
« Reply #1 on: October 09, 2018, 01:12:35 pm »
Remove the distributor cap, flip it over and check for condensation.
Offline jricharc
« Reply #2 on: October 09, 2018, 01:17:23 pm »
Will do, thanks!
