Engine/Drivetrain
Rear Drivelines, Drive Axles and Gearing
gear ratio question
Topic: gear ratio question (Read 9946 times)
dirtracer
gear ratio question
May 22, 2006, 05:59:00 pm »
I have a 43 teeth ring gear and a 14 teeth pinion gear which makes it a 3.07 gear ratio,but i didnt think chevrolet had a 3.07,thought they only had a 3.08 gear???????Also will a 3.07 or 3.08,whatever it is swap out even with a 2.56 gear in the front.Both are 12 bolt.Any help would be appreciated.thanks
81 k10
Show results
Blazin
Blazin new trails!
Gear ratio
May 22, 2006, 07:34:00 pm »
The front and rear are always off by one number from the factory. You have to have matching front and rear ratios. Example 4:11s, front 4:10s rear. or 3:72s front, 3:73s rear.
dirtracer
gear artio question
May 22, 2006, 07:49:00 pm »
What i was asking is my gear ratio with 43 ring gear and 14 pinion gear comes out to be 3.07,why is it called a 3.08 if its a 3.07?
roundedline
Re: gear artio question
May 22, 2006, 11:15:00 pm »
For generalization. .01 isn't that much to worry about.
You cannot use 2.73 with 3.08.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
http://www.73-87chevytrucks.com
http://www.captkaoscustoms.com
Engine/Drivetrain
gear ratio question
