Author Topic: Is this my Electronic Spark Control (ESC) Sensor?  (Read 3122 times)
Offline DouglasBeale
« on: October 25, 2018, 12:47:38 pm »
Is this my Electronic Spark Control (ESC) Sensor? I pulled it out of the block - drivers side between, and just above, spark plugs 1 and 3.<br><br><br>
1986 Chevy
K30
350 5.7l
4wd
dually
« Last Edit: October 25, 2018, 12:59:45 pm by DouglasBeale »
1986 Chevy K30
4WD Dually
Four Speed 117mm Transmission
NP205 transfer case
Quadrajet
Re: Is this my Electronic Spark Control (ESC) Sensor?
« Reply #1 on: October 25, 2018, 01:13:09 pm »
If you look carefully you'll see that the sensor in the image actually threads into the cylinder head between cylinders #1 and #3.  It is the engine coolant temperature switch (idiot lights) or sensor (gauges).  The ESC knock sensor threads into the right side of the engine block above and slightly forward of the starter.
« Reply #2 on: October 25, 2018, 01:19:39 pm »
Thank you. I thought it was the temp sensor, and yesterday I remove it and replaced it with a new temperature gauge, because I only had the light in the dash. But the truck was running real rough and the check engine light came on today. I thought I may have screwed something up... Probably just screwed something else up.
1986 Chevy K30
4WD Dually
NP205 transfer case
Quadrajet
