Author Topic: 700 R transmission swap  (Read 3849 times)
Offline Smitty31
  • 1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
« on: October 27, 2018, 03:21:23 pm »
I have a 1979 gmc high sierra 4x4. Engine is a 350 transmission is a 400 turbo. Will a 700 R from a 1992 chevy pickup 4x4 work in my truck
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
Re: 700 R transmission swap
« Reply #1 on: October 27, 2018, 07:02:12 pm »
You will have to come up with a transfer case adapter and transfer case as the 92 model won't work with your transfer case and adapter..
Offline Smitty31
« Reply #2 on: October 28, 2018, 10:56:26 am »
Thanks for the info. What year will work with my 79. Or is there a year that will work.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #3 on: October 29, 2018, 06:17:22 pm »
Any 4x4 700r4 should be a 27 spline output shaft, a TH400 would have a 32 spline output shaft.
So that means no matter what you do you need a NP208 or a NP241C passenger side drop that is a 27 spline input.
The transmission to transfer case adapter from a 92 could work, there may need to be an adapter to mount the tail mount support to, or even a new transmission cross member.
A complete drop in system could be had from a 1982 to 1991 square-body truck. Remember 1988-1991 was a dual year that had both square-body and the GMT400(1988-1998 style)
The best 700r4 case are typically found in 1985 and later trucks, there are also several internal upgrades that outperform earlier transmissions.
 1986 Chevy K30(under repair)
« Reply #4 on: October 30, 2018, 08:13:58 am »
cheapest way about this is to find a donor truck. you not only need the trans and transfer case but also driveshafts and you might need the cross member also. try to find a donor the same setup as your (i.e long bed for long bed or short bed for short)
