Author Topic: 2.56 to 3.07  (Read 5096 times)
Offline dirtracer
2.56 to 3.07
« on: May 23, 2006, 05:58:00 pm »
Will i be able to take the center chunk out of a 12 bolt chevrolet rear end with 3.07 gears and put it into a 12 bolt chevrolet rear end that has 2.56 gears without any problems or changing anything?
thx
81 k10
Show results
Offline roundedline
Re: 2.56 to 3.07
« Reply #1 on: May 23, 2006, 06:36:00 pm »
Not without the pinion gear.  It would be MUCH easier on yourself if you just replaced the complete 12bolt 2.73 rearend with one that has a 3.08 rearend.
BTW, only truck rearend internals are the same.  Passenger car internals won't work on a pickup.
Also, why are you putting a POLL in every post you make?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Edited by: roundedline at: 5/23/06 5:37 pm
Offline dirtracer
2.56 to 3.07
« Reply #2 on: May 23, 2006, 06:02:00 pm »
the 3.07 gears are out of a chevrolet pick up and the center chunk includes the pinion gear.as to why im taking a poll everytime i guess im not doing something right
Re: 2.56 to 3.07
« Reply #3 on: May 24, 2006, 06:42:00 am »
You need to click on new topic when posting a new post.
