Author Topic: Suburban rear spring hangers  (Read 5286 times)
Offline Jerr-conn
  • Retired tool maker
« on: November 05, 2018, 06:34:15 pm »
Tried search first- no luck. Question is-can you use stock suburban rear spring hangers on r10
Swb To lower rear 2"" ?  If yes, will they use same bolt holes with no mods? Thought I one time
read  something about this, but can't remember .Also what years will fit. Thanks.     Jerry
Jerry
Offline Jerr-conn
Re: Suburban rear spring hangers
« Reply #1 on: November 11, 2018, 08:18:55 am »
I should have mentioned that I was referring to the rear hanger of the rear spring only.
If they will lower rear 2" as I want , is bolt mounting pattern the same or will have to be
Modified ?
Jerry
