Author Topic: 96 Cheyenne not starting  (Read 5023 times)
Offline 75 C20
« on: May 28, 2006, 09:55:00 pm »
My friend has a 96 Cheyenne and its been sitting 4 a month or so...any way we hoped in it to fire her up and it turns over and over and over and over.... but it doesnt start. Its gittin gas- u can smell it after a little. It fired a couple of times a while back but  hasnt for the last how many times we have tried to start it.    Any ideas????
p.s. its got a 350
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: 96 Cheyenne not starting
« Reply #1 on: May 28, 2006, 10:43:00 pm »
Check for spark at the plugs.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: May 30, 2006, 03:13:00 pm »
As Blazin said, the best and easiest thing to start with is checking for spark.  Pop a plug off that engine and have someone turn the engine over.  Ground the plug to the metal of the engine and see if it sparks.
If it doesn't, That will take you in the right direction: ei:  coil, distributor, ignition switch, etc.
If it does spark, check vacuum, fuel pump, fuel injectors/carb, compression, etc....
SgtDel
