Author Topic: Block balance on engine stand  (Read 2647 times)
Offline Ronno6
  • Elder Student
« on: December 09, 2018, 11:27:40 am »
I have my 350 block mounted to the engine stand with the lower arms parallel to the ground.
I don't know if I can drop it farther.
The bare block itself is top heavy...a bear to roll over right side up.
Though the crank c/l is below the c/l of the stand's head mount,
I doubt that it will offset the weight of the heads and pistons,etc.
How balanced can I expect to get it, and should I be doing something different?
You can lead a man to water, but yoiu can't keep him from pissing in it.
Offline jetmech
Re: Block balance on engine stand
« Reply #1 on: December 11, 2018, 02:40:39 pm »
Yeah, They are sometimes difficult to roll over. I want to buy a stand with a gear drive and a crank over head before my next rebuild. I try to get the bottom end finished before I put the heads on and avoid rolling over after the heads are on.
'86 Sub and '86 SWB C-10
1990 454 SS
