Tie Rod on a 1984 K10
Topic: Tie Rod on a 1984 K10 (Read 11934 times)
Ozark
December 10, 2018, 05:46:01 pm »
So I'd been tracking down an issue with wobble once my truck reaches ~45, and at first I was thinking the harmonic balancer, but today I got under there and gave a tug on the tie rod and it looks like it's been through all kinds of abuse. I haven't worked on any steering/suspension before.
Check out the vid and some pics I got. Bent up like she ran over a massive buck or something.
https://youtu.be/JAEF2Hemad4
https://imgur.com/a/jJFjybA
So a few questions. What am I looking for in terms of parts? I'm looking at:
(RH tie rod) Moog ES2234R
https://www.amazon.com/gp/product/B000C57VGO
(LH tie rod, seems to include the 52" bar) Moog DS893
https://www.amazon.com/gp/product/B000C55VUW
But I'm wondering if also want one or more adjuster sleeves even though my old setup doesn't have one. DS893 seems to want to go all the way across and mate with the RH end, but I assume one sleeve could go in between them.
My plan is just to get em on there well enough to limp to the alignment shop, but if the adjuster sleeve makes the alignment job easier all the better. This looks like a good candidate
https://www.amazon.com/Moog-ES362S-Tie-Adjusting-Sleeve/dp/B000C57WMW
I'm thinking I would try to measure and match the old tie rod, but then the question is whether I should go for it in its bent state or try to eyeball/guess the length while it was straightened out.
Last question, as you can see in the vid these were previously mounted on the underside of the eye. Most of what I've seen on youtube show the tie rod ends above the eye. Which way should I go with it?
Thanks in advance!
Ozark
Re: Tie Rod on a 1984 K10
December 11, 2018, 10:35:43 am »
So apparently they make 1" and 7/8" threads versions on these. I ended up ordering ES2011R which matches the 1" of DS893, but I'm a still a bit confused about the adjusting sleeve. ES362S says it's 7/8" and I couldn't find a 1", so I'm wondering if it's just compatible by virtue of the pipe being split open down the length of it.
I also found some videos about using a taught length of string to match alignment of back wheels. I'll probably try that instead of matching the busted part.
ehjorten
December 11, 2018, 01:57:20 pm »
AC Delco 45A6011 is 1" - 18 threads.
-Erik-
75gmck25
1975 GMC K25 Camper Special, 350/TH350/NP203
December 11, 2018, 08:37:08 pm »
GM changed the design of the tie rods over the years, so I would just get the right one for your truck.
My '75 K25 has long and short tie rods, an adjusting sleeve between them, and the long tie rod has a mounting eye for a steering stabilizer. However, there are at least two other variations that were used on later trucks, including the type you have that does not have an adjusting sleeve. I guess you just screw the tie rods in and out to make the adjustment.
When I installed my new tie rods I just matched the assemly up side by side and made it all the same length. It works well and the truck tracks fine. New tie rods will almost completely remove the play you have now at the ends.
The next job to consider is ball joints, and that is a much more time consuming job. I did it last year, and used 2-3 different Youtube videos to get the description of how to do it. The only real problem I had was that it was very cold outside, which made the wheel bearing grease tough to work with. The grease set up in the cold and got so stringy that it stuck to everything.
Bruce
Last Edit: December 11, 2018, 08:38:51 pm by 75gmck25
Ozark
December 11, 2018, 09:01:49 pm »
Thanks a ton, guys.
@ehjorten you are definitely correct and the sleeve I had was too small. FWIW I ended up at NAPA and they're selling these parts with the same numbers (I don't know if they're genuine Moog or not) but I matched them before leaving and found the sleeve I needed from this manufacturer was ES2012S, same 1"-18 dimensions as that AC Delco part.
I've got it all mounted up but now I have to wait for my steering damper. I think the old damper probably had some more life in it, but the hardware holding it all together was well rusted to the LH tie rod end so I've got a Rough Country 8732530 on the way.
@75gmck25 this seems like the same design as yours, with the sleeve. I would say the whole assembly is probably twice the weight of the one I just pulled though. That probably explains the deformation. Do you think the string method for the alignment is good enough or do you take it in for them to do with laser? You got me scared of doing the ball joints now but I know it needs them too. Fortunately I've been keeping on top of the cleanup so the wife hasn't kicked me out of the garage yet!
December 12, 2018, 11:15:49 am »
just something to think about nothing will just start moving at a certain speed without energy. what i mean by that is i don't see a tie rod causing a vibration. a worn tie rod will more than likely cause odd tire wear. if you're getting a vibration its probably coming from something spinning (i.e. engine, trans, tire, rotor, drums, driveshafts and i might be missing a few) but it does sound like your tie rods are bad so its probably good to change them and you could inadvertently correct the issue like tightening a loose bolt or something
Ozark
December 12, 2018, 05:33:21 pm »
Thanks for the advice and the heads up! I will definitely temper my expectations for my test drive after I get it all reassembled when then new part arrives tomorrow.
The engine seems pretty happy in park and neutral at full throttle. I did have a problem with a sticky LH rear wheel after applying parking brake. Also, a severe screeching that I had attributed (perhaps wrongly) to the bearings in the blower motor. Possibly the bearings on that wheel? The wheel seemed to unstick after I gave it a simultaneous pull on the release lever with one hand and reaching under the cab and yanking on the cable with the other hand.
A full brake job is probably in order anyway. And if not any of that, well the transmission was behaving funny getting into gear before the new vacuum modulator so that's definitely suspect too.
I wanted a project and I sure got one, eh?
December 12, 2018, 06:51:23 pm »
does it go away after a certain speed?
dos it get better or worse when you apply the brakes?
what shape are your tires in?
are your tires missing any weights?
Ozark
December 12, 2018, 07:36:22 pm »
If you mean the wobble/vibration, the wobble starts in at around 45mph and I've only taken it up to about 60, but the wobble persisted throughout. I updated the imgur album with pics of the Chinese tires:
- I assume the clip with the "1.0 P 28" marking is the weight? If so each tire has a similar attached weight.
No immediate change with application of the brakes, but when I decelerate and reach 30ish the wobble backs off. Zero wobble under that speed. I'll try and get some video of it in action.
If you meant the screech I mentioned in my last post, the screech quit immediately when I turned the heater off which is why I had the bearings on that motor pegged.
Last Edit: December 12, 2018, 07:39:15 pm by Ozark
December 12, 2018, 07:47:50 pm »
there should/might be more than one weight (inside and outside) of the wheels. you might have to take the trim rings off the outside. but tread pattern could cause a wobble, does it change any depending on the road surface or turning?
75gmck25
December 13, 2018, 07:06:21 am »
When I've had problems with a low/moderate speed wobble in the steering, it usually turned out to be belts in the tires that have broken loose. In one case it was a rear tire (cheap tires) and you could feel it pull the rear end back and forth at low speeds. You might try swapping tires from front to rear to see if that fixes the wobble.
Don't be afraid of the ball joint work, just plan to spend some time on it. I purchased an electric impact wrench to speed up the disassembly, but borrowed all the other special tools from Autozone. Take pictures along the way so you can remember how various parts go back together, and only take one side apart at a time so you can make comparisons. The one item that is really tough to get off (lots of banging with a hammer) is the steering arm, and it has special retainers that look like washers under the nuts. The retainers are actually a cone-shaped piece that recessses into the hole and also acts as a washer.
You will find there are multiple seals to replace, and trying to get the parts guy to find the right one will be frustrating. I had to make a couple trips to the store after they sold me the wrong seals the first time. You also have an opportunity to look at brake pads, discs, bearings and other parts while you have it apart. I ended up only servicing and replacing brake pads, but tried to do a good inspection of wear on other parts.
Bruce
Ozark
December 16, 2018, 04:34:44 pm »
Just a quick update: Amazon delayed my steering stabilizer so I didn't get everything back together until yesterday. She's driving a lot better now and the original wobble is gone (the one that started at speed), but it's pretty shaky when I apply brakes -- I'm guessing I had two separate issues going on.. I'm thinking I'll start with the rear shoes and bearings and then tackle the front and ball joints after that. I think mine is rear drum brakes and front disc? Let me know if anyone has any pointers or videos/parts!
75gmck25
December 17, 2018, 06:48:11 am »
The most common repair for braking vibration would be to have the discs and/or drums turned by a machine shop to even them out, and then put on new brake pads. The machine shop should have the specs on how thin they can be before replacement, or you might just look for a good price on new discs and drums.
The discs will have to come off for the ball joint replacement, so you might just wait until then to get the front brake work done.
Since you have a K10, rear brake drums are also easy to remove if you just make sure the park brake is fully released. It might take a little light hammering to break the drum loose from the wheel studs, but that's usually just rust holding it on. In a few cases there may be slip-on retainer clips over the wheel studs, but they just pull off with a pliers.
Inside the drums you will find the brake shoes and the wheel cylinders. Take a very close look at the wheel cylinders for any leakage, since that is also a common problem. If you open it up to do new brake shoes and turn the drums, I'd consider replacing the wheel cylinders also. The only downside is that you will have to bleed the brakes if you replace the cylinders.
Also take a close look for big cracks or any bulging in the flexible brake lines that run from the axle over to the wheel cylinders. As they get older, the flexible lines may soften and bulge under pressure, and when they bulge you are losing brake pressure every time you step on the pedal.
Bruce
Ozark
December 17, 2018, 09:32:47 pm »
Thanks Bruce! I captured a bit of video if you'd like to see what I'm seeing inside the drums. I'm a bit perplexed why things are looking so different between the two -- I think it may indicate that the LH side is the only one doing all the braking (no dust on the RH side).
Clips of the drums:
https://youtu.be/Nrc-lhrp5nM
https://youtu.be/U63hCqwiiMY
One question I have is how to pop the seal to get to the bearings if I want to change them out. And I think there's a spindle nut socket I may need but I'm not sure where to look to find the size I might need?
Also when I give the wheels a spin my gut tells me they're not spinning as freely as they ought to be, but I don't have a point of comparison. Finally, I'm looking at the bottom of the rear differential plate
https://imgur.com/60mU5rd
and wondering, what could cause that discoloration? Ongoing leak or just from the last time the fluid was changed?
Last Edit: December 17, 2018, 09:36:03 pm by Ozark
75gmck25
December 26, 2018, 07:43:06 am »
Does your emergency brake work, and do you use it? IIRC, the rear brakes have a ratcheting mechanism that self-adjusts each time you use the emergency brake. If its not pulling the cables right you may not be getting the right adjustment on each side, which would leave one side looser than the other.
Bruce
