Author Topic: Mystery wires  (Read 4948 times)
Offline januarytiger
Mystery wires
« on: December 17, 2018, 10:08:25 pm »
Hi all,
Asking my for help with newly acquired 86 c10
Found mystery wires
Pink with black stripe on passenger side
solid green on driver side
I have 1986 C10 custom deluxe
4.3 carbureted v6 (quadrajet 4 barrel)
No a/c
No power steering
No power brakes
I’ll attempt to post pic
I’ve been trying to post pic but I get
this message
What am I doing wrong?
image2.jpeg.
You cannot upload that type of file. The only allowed extensions are doc,gif,jpg,mpg,pdf,png,txt,zip.
Thanks for help and in advance
John
« Last Edit: December 19, 2018, 12:08:10 pm by januarytiger »
1986 C10 Custom Deluxe 4.3 V6
Quadrajet 4 barrel
3 speed Manual transmission column shift
NO; A/C, Power steering, power brake
Offline Rapid Roy
  • Euless, Texas
Re: Mystery wires
« Reply #1 on: December 18, 2018, 06:22:52 am »
Welcome
Mopar by Birth
Chevy by Choice
Re: Mystery wires
« Reply #2 on: December 19, 2018, 08:27:13 am »
Solid green is probably for the coolant temp sensor
Re: Mystery wires
« Reply #3 on: December 19, 2018, 03:21:32 pm »
Pink with black stripe is the standard color code for fused ignition power.  Does the truck have an air management system (smog pump)?
Re: Mystery wires
« Reply #4 on: December 19, 2018, 06:49:18 pm »
Yes
Smog pump is on
Actually I’m replacing all vacuum lines and I
have questions about emissions but don’t know what topic to post in, engine?
Quadrajet 4 barrel
Re: Mystery wires
« Reply #5 on: December 19, 2018, 07:39:11 pm »
That's a 480 Metripack connector P/N 12015952.  It is probably intended to power a throttle kicker solenoid.
