Author Topic: Chatter  (Read 5520 times)
Offline 1980cdeluxe
Chatter
« on: June 15, 2006, 09:10:00 pm »
Well, I've never really ran the 250 hard since I bought it... I always thought it was a bit pimpsy so earlier I was gagging on it and noticed anything out of first gear I get a chatter at full throttle. If I don't give it full throttle it's fine. The only time I can really mash it is in 1 up to 2, but not into 3rd.. Muncie transmission, any clue on what to check? I'm thinking of changing the plugs and distributor cap/button + wires soon. I think it could be the gas too, or the timing.. I tried fooling with the timing a bit this afternoon but it didn't help much.  Any suggestions are welcome!
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
> Chatter
« Reply #1 on: June 15, 2006, 09:19:00 pm »
Chatter?  When i think of that, i think of clutch/pressureplate/throwout bearing
Does it seem like it is coming from motor or drive train/ tranmission?
How old is your clutch disc / pressure plate?  You don't want to put too many hot spots on fly wheel or you wont be able to turn it anymore.
SgtDel
Offline 1980cdeluxe
Re: > Chatter
« Reply #2 on: June 15, 2006, 10:22:00 pm »
Motor chatter, sorry didn't specify that.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: > Chatter
« Reply #3 on: June 17, 2006, 01:55:00 am »
I am assuming you are referring to valve knocking.  It's called detonation or pinging. If so,
One word, timing.
Retard your timing a tad.  turn distributor a tad clockwise--to retard the spark just a hair. Then see what happens.
Try a higher octane and see if that stops the problem.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel  at: 6/17/06 1:03 am
