Author Topic: Mystery Compression Ratio  (Read 3062 times)
Offline JohnnyPopper
  • Old Goof
« on: January 05, 2019, 07:56:49 am »
I just installed a slightly used crate 350 in my K10, runs good.
I have no specs on the motor, came in a '80 I'm going through, former owner said it was fresh.
But I have a lingering question: can actual compression PSI measurements indicate the C/R?
Is there any data that shows what level(s) PSI would be, relative to that displacement?
Kind of backward engineering but it's not worth pulling apart to find out the mystery.
Any thoughts?
1980 C-10 under construction
Offline Ronno6
  • Elder Student
Re: Mystery Compression Ratio
« Reply #1 on: January 05, 2019, 08:07:08 am »
Many variables come into play, but this article explains things:
http://www.healey6.com/Technical/Nominal%20compression%20pressure.pdf
In essence, cylinder pressure should be between 15 and 20 X the C/R.
That should give you an estimate.........
You can lead a man to water, but yoiu can't keep him from pissing in it.
  • Old Goof
« Reply #2 on: January 05, 2019, 06:30:04 pm »
Ronno6 you are the Man!!
Thanks so much, I'll post what I find.
