Author Topic: Amp gauge discharge  (Read 3802 times)
Offline Breynolds1107
Amp gauge discharge
« on: January 20, 2019, 04:35:31 pm »
Ok I have 1985 k30 crew truck runs fine with all lights on except dash lights  when I turn on dash lights causes discharge an fuel gauge to drop as soon as I turn dial back it will go back up I have checked grounds and replaced alternator what could the problem be
Re: Amp gauge discharge
« Reply #1 on: January 20, 2019, 05:58:02 pm »
An 85 K30 should have a voltmeter, not an amp gauge.  Disassemble and burnish the ground connections to shiny bare metal.  Concentrate on the I/P harness connections to the instrument cluster PC board, the ground connections to the park brake frame under the dash at the left kick panel, the braided jumper between the firewall sheet metal and the back of the passenger side cylinder head, and the battery to engine ground cable.  Check the PC board for cracked or peeling foils.  Make sure that none of the I/P harness black ground wires are severed.
Offline Rapid Roy
  • Euless, Texas
« Reply #2 on: January 20, 2019, 06:11:05 pm »
Welcome
Mopar by Birth
Chevy by Choice
