Author Topic: Vbelts  (Read 5245 times)
Offline edgaruquintero
Vbelts
« on: January 28, 2019, 08:37:10 pm »
Thanks for letting me join! Does anyone have info for vbelts swap to serpentine belt on a 350tbi . Its an 87 square body , from my research the 90s 350 vortec has same block? Therefore use same brackets for pulleys etc?
Offline Rapid Roy
  • Euless, Texas
Re: Vbelts
« Reply #1 on: January 28, 2019, 09:31:52 pm »
Welcome
Mopar by Birth
Chevy by Choice
Offline MrFiveOh
  • The Local Po-Po
Re: Vbelts
« Reply #2 on: January 29, 2019, 11:52:57 am »
you can use the serp setup from the 88-98 obs trucks. you can also use the serp setup from the smaller trucks or from a car, those tend to bring the serpentine setup closer together and make it look cleaner
1974 C-10 AKA "Smurf"
Offline 75gmck25
Re: Vbelts
« Reply #3 on: February 06, 2019, 07:34:27 am »
I've also seen some combination GM setups in the junkyard, where the main belt is a serpentine, and I think it was the A/C that is running off a separate V-belt.
Bruce
