Author Topic: Speedometer - why wires?  (Read 11393 times)
Offline Mr Diesel
  • Aaron
« on: February 07, 2019, 06:30:16 pm »
Doing a bunch of re-wiring on my 1983 K30, trying to remove and fix a lot of the previous owner wiring hack jobs. Pulled the instrument cluster and discovered factory wires attached to back of the speedometer. Can't tell where they go, and my Haynes manual wiring schematic wasn't much help. Did GM use this for the cruise control or something?
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline MIKE S
  • Member
Re: Speedometer - why wires?
« Reply #1 on: February 07, 2019, 06:54:13 pm »
Should be speed sensor to ECM input for transmission and cruise control if equipped.
« Reply #2 on: February 07, 2019, 07:37:17 pm »
See below.  IIRC wire colors are red, green, black.
Offline Mr Diesel
  • Aaron
« Reply #3 on: February 08, 2019, 05:48:05 am »
 I suspected it was for cruise control, but until now thought the original cruise system was entirely mechanical with no electronic portion.
That picture above matches exactly, and the wire colors are red, green, black.
Thanks for the replies!
Offline hatzie
« Reply #4 on: February 10, 2019, 08:43:12 am »
This is the GM Service Training Textbook for the Cruise III systems.
If you intend to revive the cruise control it'll answer some questions about how that system worked.
http://www.mediafire.com/file/j5cws4inxl5q853/1984_CRUISE_III.pdf/file
« Last Edit: February 10, 2019, 08:45:31 am by hatzie »
Offline Mr Diesel
  • Aaron
« Reply #5 on: February 10, 2019, 03:01:24 pm »
Thanks for the link. Very useful information. I saved it to print out later because I would like to get original cruise working again some day.
Offline hatzie
« Reply #6 on: February 11, 2019, 02:08:45 pm »
Depends on what's knackered whether it's worth fixing Cruise III.
It didn't have a stellar reputation for reliability and the parts are not cheap.
You may find it's easier and more cost effective to install a Rostra unit or a GM Electromotor cruise from an early 90's T400 truck or F-body.
Offline Mr Diesel
  • Aaron
« Reply #7 on: February 12, 2019, 09:13:11 am »
I think I have all the spare parts to make it work again. The truck actually had an aftermarket cruise system installed already and the manual for it was in the glove box so I could fall back on it too.
My wife's 1987 camaro has the original cruise control system still intact and it works as good as any new car I've ever driven.
Offline Johnret
« Reply #8 on: February 04, 2020, 06:17:38 am »
What aftermarket Cruise System does it have?
