Author Topic: More fuel line problems.....help  (Read 4688 times)
Offline 85silverado
« on: July 05, 2006, 07:15:00 pm »
I Recently had a leaking fuel line from the fuel pump to the carb, so i replaced it with a new one and now it leaks on both ends and i'm having a tuff time getting it to stop. I saw teflon tape on the factory line, do these double flared lines need teflon tape?
Offline DnStClr
Re: More fuel line problems.....help
« Reply #1 on: July 05, 2006, 11:50:00 pm »
No teflon tape is needed on a flared fitting. The thread pitch is different than a pipe thread. A leak at a flared fitting is usually a sign that the flare is cracked or the fitting isn't tight enough. But if the fitting is overtightened, it will crack the flare.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
