Interior & Equipment
Original radio wiring
Topic: Original radio wiring (Read 18918 times)
uprising
February 21, 2019, 02:35:38 am »
Hi guys,
i removed my bezel and paste some gauges, refurbish the shift indicator and now i try to get the original radio connected. Does the Radio has a cl.30 connection or cl.15? Which color does the cable normally have? Is the wire come from the fusebox or is it going first to the „Headunit“ and from there to the radio? Actually i have only connected the dashspeaker. Can i easly connect side speakers?
I only have a wiring from a 80‘ truck...
bd
Re: Original radio wiring
February 21, 2019, 09:19:56 am »
Factory wire colors to power the radio are yellow (12v ignition from fuse box), black (ground to cabin sheet metal), gray (panel lamp power from fuse box). Speaker colors are variable dependent on RPO.
1980 Wiring Manual
What are cl.30 and cl.15 connections? Is it a monophonic or stereophonic radio? What are you referring to as the "Headunit?"
uprising
February 21, 2019, 12:16:33 pm »
Thanks for your quick answer!
Cl.30 is supply from battery and cl.15 is ignition
It is the original from 1975
I think it is a mono radio! But i‘m not sure...
With headunit i mean the whole instrument box. Come the radio wires directly from the fusebox or from another place?
bd
February 21, 2019, 02:15:26 pm »
1975 Wiring Manual
Ignition power (15) arrives directly from the "RADIO" fuse of the fuse box through a yellow wire. The yellow wire should be in a taped harness along with one gray wire (radio illumination) and one black wire (ground). The speaker wires (usually tan and gray) should run to the radio separately from the power wires.
philo_beddoe
77 C-10
November 04, 2022, 07:53:20 am »
So where is the best and closest place to connect this black ground (radio) wire? Cabin sheet metal??
Last Edit: November 04, 2022, 08:26:53 am by philo_beddoe
Rapid Roy
Euless, Texas
November 04, 2022, 09:16:12 am »
I connected mine to the very bottom of the dash with metal screw.
Mopar by Birth
Chevy by Choice
philo_beddoe
77 C-10
November 04, 2022, 01:34:28 pm »
I'll try it...
bd
November 04, 2022, 01:42:34 pm »
The factory location is the e-brake pedal frame at the left kick panel...
...but any convenient bare sheet metal point should work fine.
philo_beddoe
77 C-10
November 04, 2022, 04:20:23 pm »
Ok, found it. Thanks for clarifying!
