Author Topic: Largest tire size achieved with 2 inch lift?  (Read 11851 times)
Offline LongBox85
« on: February 25, 2019, 06:17:09 pm »
I've got my 1985 K20 with 2-inch blocks and an add a leaf in the rear, and 2-inch lift in front. What is the largest tire size any of yall have squeezed under there with a 2-inch lift?
Radio? Who needs a Radio? -- Lloyd Christmas.
Offline Captain Swampy
  • Wisconsin
Re: Largest tire size achieved with 2 inch lift?
« Reply #1 on: February 25, 2019, 09:44:20 pm »
I'd guess 33 or 35 inch tires. Hopefully  someone that knows will comment.
Offline ehjorten
« Reply #2 on: February 26, 2019, 09:00:04 am »
Should be 33" if you want full suspension articulation and no body panel trimming.
-Erik-
Offline fitz
« Reply #3 on: February 26, 2019, 12:07:47 pm »
A lot depends on the width & offset of your rims.
Offline roundhouse
« Reply #4 on: February 27, 2019, 11:50:40 am »
I’ve run 33 with no lift
Depends a lot on the wheels and if you don’t mind it running a little when you turn in a driveway or something
Offline ehjorten
« Reply #5 on: February 27, 2019, 01:46:02 pm »
Skyjacker has a chart: https://skyjacker.com/skyjacker-tire-and-wheel-chart-download/
As others have said...it does depend on the wheel and tire combo and how you use the truck.  My opinion is that I want full articulation of suspension without rubbing or trimming fenders.
-Erik-
« Reply #6 on: February 27, 2019, 03:24:59 pm »
what do you mean by 2" blocks? a body lift or suspension?
Offline LongBox85
« Reply #7 on: February 28, 2019, 11:47:36 am »
Irish_Alley, I meant suspension lift. Blocks in the rear. Thanks for the info.
« Reply #8 on: February 28, 2019, 12:22:11 pm »
so you have blocks and add a leafs in the rear? anyway i run 33s with no lift and they rub while full turning and sometimes hitting bumps while turning
Offline LongBox85
« Reply #9 on: March 03, 2019, 04:14:01 pm »
Correct, blocks and add-a-leafs
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #10 on: May 24, 2019, 01:34:06 am »
I got 275/70R18 on my C20 with 1.5 lift blocks in the rear and 454 front coils.  They should be 33.4" tall.  I'd think 33's or maybe 34's on a 4x4.
Offline 86bluestocker
« Reply #11 on: May 29, 2019, 08:48:51 pm »
When i bought my 86 c10 the previous owner did a 2 inch suspension lift, blocks on the back, hd springs in the front (2wd) it had 33/12.50 R17 with some pretty tall tread mt's, never rubbed
Sent from my SM-N960U using Tapatalk
