Author Topic: 6.0lq4/4l80e/261 swap?  (Read 6629 times)
Offline stoadvine
« on: April 01, 2019, 12:27:55 pm »
I have a donor 2002 2500 had with a 6.0/4l80e/manual 261 and want to run it in my 86 k20. Can anyone tell me if this will work? I can’t seem to find any threads with someone using this transfer case. I also wanted to use the rear axle with disc brake setup. Any advice is appreciated.
Re: 6.0lq4/4l80e/261 swap?
« Reply #1 on: April 01, 2019, 08:04:39 pm »
if the 261 is a driver side drop it wont work but supposedly you can drop a ford front axle in place as theyre drivers side drop. you could also find a 241 off a th400 that has electric speedo and make that work
