Author Topic: 2500 RPM miss, need help  (Read 8056 times)
Offline 454FOTF
« on: July 20, 2006, 12:46:00 am »
I have a '79 C30 with 454.  I get missing and lose power around 2500 rpm.  My tachometer loses power when this missing occurs and drops to zero.  When I let up on the gas pedal and the rpms come down a little the missing subsides and the tach returns to normal.  I have replaced the distributor cap, rotor, coil, spark plug wires, ignition module, and vacuum advance.  Timing is set at 9 degrees before TDC at hot idle with the vacuum advance disconnected.  Spark plugs all look good and are gapped at .035
Anybody have any ideas on what I should check next?
I have thought that maybe there is resistance in the 12V supply wire going to the distributor or maybe there is resistance in the harness.
Does anyone have any resistance specs that will help me diagnose?
Offline cjtimp
Miss
« Reply #1 on: July 20, 2006, 06:10:00 pm »
May be vaccum leak too.....................check vaccum
Offline 454FOTF
Re: Miss
« Reply #2 on: July 20, 2006, 09:50:00 pm »
not sure how a vacuum leak could be the problem when the tach drops to zero when it's missing.  I guess there could be a different problem affecting the tach.  I'll the vacuum just in case.
any other ideas?
Offline 123 pugsy
Re: Miss
« Reply #3 on: July 21, 2006, 07:29:00 pm »
Could there be a problem caused by the alternator when it gets to the 2500 RPM mark???
Only thing I could think of that affects electrical and goes with the engine turns.
Pugsy
76 C10 LWB
TPI 350
Offline 454FOTF
Re: Miss
« Reply #4 on: July 22, 2006, 01:33:00 pm »
thanks for the thought about the alternator.  I'll check the voltage at 2500.
I wiggled the two harnesses that plug into the distributor and that appears to have stopped the miss so far but my tach continues to loose power at 2500.  Although, now it is only dropping to around 1500 even though I am revving much higher.
Offline roundedline
Re: Miss
« Reply #5 on: July 25, 2006, 05:18:00 pm »
are you trouble shooting a broken tach, or is the motor dropping rpms.  The stock tach clusters are notorious for being not so accurate.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 454FOTF
Re: Miss
« Reply #6 on: July 26, 2006, 12:33:00 am »
It now appears that the miss has been cured by wiggling the wires going into the distributor.  Yes, now I only have the issue with the tach.  The tach works fine until you push the engine past 2500 rpm, at which time the needle starts to drop back toward 1500 rmp as the engine increases speed.  Not a major problem, just annoying.   Is this a common problem from these OEM tachometers?
I thought the two problems were related before because the miss and tach failure occured at the same time.
