ball joint slides right out, solutions?
Topic: ball joint slides right out, solutions? (Read 16525 times)
88rxna
always learning..
84c10 with 1990 quad blazer grill/light upgrade questions
Reply #15 on:
May 06, 2019, 07:57:29 am »
What would be the difference between the c10 and c20 lca's?
I do know the stem on the ball joint im trying to replace is the same size as the new ones.
Last Edit: May 06, 2019, 08:27:33 am by 88rxna
1984 custom deluxe C10
4.8 sloppy stage 2 cam with springs
s480
xmax terminator
4l80E
JohnnyPopper
Old Goof
Re: ball joint slides right out, solutions?
Reply #16 on:
May 06, 2019, 02:33:45 pm »
C10 is 1/2 ton.
C20 is 3/4 ton.
I bet someone put a C20 arm on your passenger side.
Go to Napa and measure a 3/4 ton ball joint.
1980 C-10 under construction
88rxna
always learning..
Reply #17 on:
May 06, 2019, 03:24:09 pm »
Both sides are the same. The ball joints littlery fall right out. I'll measure them and post pics
Sent from my SM-G920V using Tapatalk
s480
xmax terminator
4l80E
88rxna
always learning..
Reply #18 on:
May 06, 2019, 03:37:07 pm »
This came off the control arm and this is the driver side arm. The ball joint measured 1.90 and the hole is 1.80
Last Edit: May 06, 2019, 03:38:58 pm by 88rxna
s480
xmax terminator
4l80E
88rxna
always learning..
Reply #19 on:
May 06, 2019, 03:39:39 pm »
The NAPA oversized measures at 1.78
Also, I ordered and installed c10 poly bushings into the passenger side control arm which I have the same problem with. Aren't the bushings different sizes?
s480
xmax terminator
4l80E
JohnnyPopper
Old Goof
Reply #20 on:
May 06, 2019, 05:32:29 pm »
Dude!
How can a ball joint measure 010. bigger than the hole it came out of?
Dumb question but are you measuring the diameter at the same point on each?
Do you have before and after pics of the ball joints? this is getting very strange.
I would go to Napa and measure a 3/4" ball joint.
88rxna
always learning..
Reply #21 on:
May 06, 2019, 05:52:43 pm »
I tried closing them with a cold chisel and hammer after the new ball joints were lose by hitting around the outside of the socket.
I just bit the bullet and bought new control arms from . I'm not gonna chance it.
s480
xmax terminator
4l80E
Reply #22 on:
May 06, 2019, 08:48:58 pm »
Quote from: JohnnyPopper on May 06, 2019, 05:32:29 pm
Dude!
what i was thinking is that he measured the ball joint on the outside of the splines and when he measured the whole it didnt include the splines as they cut into the control arm
MIKE S
Member
Reply #23 on:
May 06, 2019, 10:09:39 pm »
I don’t know what they are giving you but I just measured an extra new master pro K6117 that is 1.945 at the bottom and 1.80 at the top..
ezstriper
Reply #24 on:
July 06, 2020, 03:15:17 pm »
ran into that once before, moog does sell a oversize one
