Author Topic: 74 c-20 wheel options?  (Read 8945 times)
Offline tcj
« on: May 01, 2019, 10:49:14 am »
I'm new here, so thank you in advance for any info you might have.
I have a 74 c-20 with the original 16.5s
Stock steels.
I love the look, but I'd like to upgrade to a 16"or 17" in the same style rim so I can put a better tire on the truck.
Offline Rapid Roy
  • Euless, Texas
Re: 74 c-20 wheel options?
« Reply #1 on: May 01, 2019, 11:19:46 am »
Welcome
Mopar by Birth
Chevy by Choice
Offline tcj
« Reply #2 on: May 01, 2019, 12:14:16 pm »
Thank you.
Also forgot to mention its a 2wd.
Offline tcj
« Reply #3 on: May 01, 2019, 12:16:51 pm »
« Reply #4 on: May 02, 2019, 07:46:48 am »
there is a 16" option in the steel wheel that accepts a hubcap.  I don't have many pictures this way because I've changed to the newer style wheels
« Reply #5 on: May 02, 2019, 07:50:28 am »
I like the 99-06 style in either steel or aluminum
Offline tcj
« Reply #6 on: May 02, 2019, 08:37:23 am »
Thanks anyways, I finally found these last night.
Offline tcj
« Reply #7 on: May 02, 2019, 08:38:44 am »
...but if anyone has any leads on 10" wide please let me know.
Offline 75gmck25
« Reply #8 on: May 04, 2019, 06:40:09 am »
I switched from 16.5 split rim to stock 16" 8 bolt wheels I got from pick and pull.  I paid about $25/wheel, and then bought tires to match.  However, these are stock width rims (8"?).
If you have a high GVW C-20 (my K25 is 8200 lbs GVW) you need to use 10 ply/E load rating tires to maintain the cargo capacity.   They are a little more than standard truck tires, but still easy to find. Stock height tires are usually 245/75R-16E - about 31" tall.
Bruce
Offline tcj
« Reply #9 on: May 04, 2019, 07:21:22 am »
Thanks for the reply.
I ended up picking up a 10 ply 235/65/16
Which will keep it the 28" it's currently at.
Offline Stewart G Griffin
« Reply #10 on: May 06, 2019, 02:51:38 pm »
It's probably too late, but for future reference, i think this place has them in 10" wide.  i don't have time to research:
https://www.cokertire.com/wheels/truck-wheels.html
