Author Topic: Starting your engine  (Read 4718 times)
Offline gbskunk2006
« on: August 07, 2006, 11:44:00 am »
My truck has been off the road for about nine months now while I worked on restoring it.  The engine is a 4.3 Litre V6 with almost 280,000 KM but ran like a charm which is why I've decided to wait a couple more years before rebuilding it.
What's best way to "pre-lube" the engine components before actually firing her up?
Thanks in advance.
community.webshots.com/ph...5031dIxizi" class="bbc_link" target="_blank">[img]thumb11.webshots.com/t/58...h.jpg[/IMG]
Edited by: gbskunk2006 at: 8/7/06 10:57 am
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
Offline roundedline
Re: Starting your engine
« Reply #1 on: August 07, 2006, 12:53:00 pm »
Well, you "could" pull the distributor and prime the pump till you get Pressure before cranking it like you would before break-in.
I personally would just crank it.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
