Author Topic: rearend swap  (Read 5425 times)
Offline daman02
rearend swap
« on: August 03, 2006, 11:32:00 pm »
i am going to swap out a 10 bolt rearend to a 12 bolt rearend out of a 78 big 10 into my 86 c10 silverado and i have a few ?'s.  Is the overall length going to be the same, will it bolt right up to my leaf springs or will mods be required, and if there is anything else that someone might think of that will be appreciated as well.
'86 C10 Silverado 350 with 700r4 and 2500 stall
Dropped 2" in front and 2" in rear but soon to b 4" in rear
18x10 wheels with 295/45 18 tires
Offline roundedline
Re: rearend swap
« Reply #1 on: August 04, 2006, 11:23:00 pm »
It will bolt right in.  Problems will be with the Pinion Yoke not matching your driveshaft.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline daman02
Re: rearend swap
« Reply #2 on: August 06, 2006, 01:54:00 am »
what would have to be replaced to make it work?  as usual i appreciate your input
Offline 123 pugsy
Re: rearend swap
« Reply #3 on: August 06, 2006, 12:48:00 pm »
You would have to change the driveshaft or have a driveline guy customize your existing.
A new U-Joint also.
Pugsy
76 C10 LWB
TPI 350
Offline roundedline
Re: rearend swap
« Reply #4 on: August 07, 2006, 12:54:00 pm »
Ditto on above.
You also may be able to get a hybrid u-joint and make it work also.
Project Su
Jimmy 2WD Project
