Author Topic: power steering pump  (Read 5449 times)
gpday06
  • Guest
power steering pump
« on: August 05, 2006, 04:49:00 pm »
im changing the power steering pump on my '79 C10 and i cant get the pulley off of the old pump, how do i get it off?
Edited by: roundedline at: 8/7/06 12:56 pm
Offline 123 pugsy
Pulley
« Reply #1 on: August 05, 2006, 05:01:00 pm »
Have you tried a pulley puller?
Pugsy
76 C10 LWB
TPI 350
gpday06
  • Guest
Re: Pulley
« Reply #2 on: August 05, 2006, 05:05:00 pm »
no whats that, and i already have it off, the olp pump that is how does the tool work, like a slide hammer?
Offline Z28 c10
Re: Pulley
« Reply #3 on: August 05, 2006, 07:47:00 pm »
The puller works alot like a balancer puller, it has a 2 peice cup that fits around the ring on the end of your pulley and a bolt that acts as a jack bolt that pulls the pulley off. You will also need it to put the pulley on the new pump. You should be able to rent the kit at either advance or Auto zone. Your going to pay like 30 or 40 bucks for it to rent, but they give the money back if you don't mess it up or lose peices to the kit.
 JayTater
 Z28 C10
PS you might want to go back and edit your language a little, Roundedline will give you the what for.
Offline 123 pugsy
Pugsy
76 C10 LWB
TPI 350
