Author Topic: 305 TBI timing ?  (Read 9554 times)
Offline 87swb
305 TBI timing ?
« on: August 08, 2006, 01:06:00 pm »
i know you need a timing light but is there any trick to timing a 305 TBI or any SBC V8 without using a timing light. could you eyeball the distributor and tell it's in the right spot. i accidentally knocked my distributor around:rolleyes :o
Offline roundedline
Re: 305 TBI timing ?
« Reply #1 on: August 08, 2006, 01:41:00 pm »
Offline 87swb
305 TBI timing ?
« Reply #2 on: August 08, 2006, 02:06:00 pm »
oh ok, just makin sure. my truck still cranks and runs but i know its off, it's pings some when i drive it and doesn't seem to have as much power, it's startin' to bother me.
Offline Stewart G Griffin
« Reply #3 on: August 08, 2006, 02:24:00 pm »
Speaking of timing, how would you time a stock 305 (mine is carbed not tbi)
Should i just get the mark at 0 degrees with the vacuum unpluged?
Offline roundedline
« Reply #4 on: August 08, 2006, 02:40:00 pm »
I would start it at 10 degrees initial with the vacuum unhooked to set it.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #5 on: August 08, 2006, 07:09:00 pm »
If you don't have a timing light to use right now and your engine is rattling under load, turn your distributor clockwise just a tad (retard timing).  Do this just a tiny bit at a time 'til it goes away.  If you go too far, well, it will be too retarded---that doesn't sound right for an inanimate object. :lol
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
