Author Topic: fuel vapor canister  (Read 20749 times)
gpday06
  • Guest
fuel vapor canister
« on: August 10, 2006, 03:11:00 pm »
what exactly do the fuel vapor canisters do? i believe that they just take the vapor concentrate it into a fuel and send it to the carb to be burnt, but im not sure, and since i have a 79 with dual tanks i dont have to worry about emissions, so could i just bypass them some how?
Offline DnStClr
Re: fuel vapor canister
« Reply #1 on: August 10, 2006, 07:28:00 pm »
That's what it does, but the vapors don't concentrate into a liquid.  The vapors are drawn into the carb or intake manifold (if tbi) by vacuum so they can be introduced into the burn cycle. Removing the cannisters isn't necessary, even tho a lot of us do it.. It helps clean the air by not allowing the unburned fuel to release into the atmosphere.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Offline 123 pugsy
« Reply #2 on: August 11, 2006, 06:15:00 am »
Also helps to vent the tank.
Pugsy
76 C10 LWB
TPI 350
gpday06
  • Guest
« Reply #3 on: August 11, 2006, 02:32:00 pm »
thanks, thats what i needed to know
