Author Topic: Electric Metering Rods Carb Question  (Read 6642 times)
Offline Harmon
« on: June 01, 2019, 07:58:47 pm »
1986 Chevrolet C 10 350 Engine
I am wondering where the electric connection that hooks up at front Passenger side of Carburator goes too.  I am eliminating smog pump/various vacuum lines not needed and am wondering if the electronic metering rods need vacuum, or if that electrical connection mentioned above snakes back behind the engine and connects to a switch that has vacuum to it?
Thanks for any insight.
Offline Stewart G Griffin
Re: Electric Metering Rods Carb Question
« Reply #1 on: June 01, 2019, 09:02:57 pm »
First, are you sure you have electronic metering rods?
i guess the other question i should ask is, are you in California?
Offline Harmon
« Reply #2 on: June 01, 2019, 09:53:52 pm »
Im in Texas, and its the carb that has the wires going to the front of the carb.
« Reply #3 on: June 02, 2019, 11:13:20 pm »
Could you take a picture of it, because i think you may have a dual capacity accelerator pump instead of the electro-metering rods, but we'll see what we'll see....
