Author Topic: Replacement 2 barrel carburetor options???  (Read 6905 times)
Offline Dave W
« on: June 08, 2019, 05:26:21 pm »
 :oI have a 78 2wd c10. 305v8 2 barrel rochester.
I bought a refurbished Rochester about a year ago
And always had trouble with the fuel inlet leaking.
I tried the self tapping re-thread fixture.. no luck.
Tried it again with some marine JB weld it is about 90%
Good.
But I know eventually I may need to replace it.
Any other makes in 2 barrel NEW out there, (carter/holley)that will bolt right up?
I know I may possibly have to go to a manual choke with some
Brands.
Under $350 budget
Thanks in advance!!
« Last Edit: June 08, 2019, 05:40:20 pm by Dave W »
Offline Stewart G Griffin
Re: Replacement 2 barrel carburetor options???
« Reply #1 on: June 08, 2019, 06:18:53 pm »
Sorry i can't help too much at the moment.
i had the exact same problem on a 2G reman.  Most remans are not really that good.   i went to the junkyard to get a factory inlet and problem solved.
If it has to be new, then a holley 2300 may sort of bolt in with an adapter.
Or get a high quality reman from a more reputable rebuilder.
Or get a new intake---then you'll have plenty of new 4bbl carbs to choose from ;D
i'll try to add more later.
P.S.
If it's leaking, DON'T RUN IT.
« Reply #2 on: June 08, 2019, 06:28:17 pm »
The other thing you could do is go TBI, but that's going to be more than the $350 budget......
« Reply #3 on: June 08, 2019, 06:35:02 pm »
Brand new  Weber 38-DGES would be neat.
Sorry, not trying to blow you off----i'm just busy.
This topic fascinates me---if i didn't overheat my 305, i would still be  running a 2G.
« Reply #4 on: June 14, 2019, 01:06:15 pm »
Offline JohnnyPopper
  • Old Goof
« Reply #5 on: June 14, 2019, 03:23:41 pm »
Nice find!
I run a Qjet on a 350, but wonder if this would make a good replacement.
I may call the 'expert' hotline right after I fill my diff with a ziplock  bag full of SAE 90!
1980 C-10 under construction
  • Old Goof
« Reply #6 on: June 14, 2019, 06:55:12 pm »
So digging a little deeper, they may a direct QJet replacement, however they're for non-emission vehicles.  :(
Any word if SEMA is still working on raising the smog years to 1980?
