Author Topic: New To this Forum, Bought a 1987 C20..  (Read 12807 times)
Offline JohnnyPopper
  • Old Goof
Re: New To this Forum, Bought a 1987 C20..
« Reply #15 on: June 24, 2019, 02:13:49 pm »
Sounds like you have a cooling problem.
Popping sounds usually come from water boiling in the block when it's real hot and your radiator cap is not holding pressure.
The heater core is the closest part of the cooling/circulation system, so you would hear it.
Bypassing it does not mean you've corrected the problem.
Check your cap for a cracked seal or other cooling issues.
1980 C-10 under construction
« Reply #16 on: June 24, 2019, 07:53:49 pm »
Quote
My mechanic say the fix to it is to put in a very small. mabee 1/4 inch size restrictor tube in the heater Hose lines to reduce the amount of flow through the heater core...
I think your best investment is a new mechanic.
« Reply #17 on: June 24, 2019, 08:02:29 pm »
Offline 75gmck25
« Reply #18 on: July 05, 2019, 07:30:48 am »
Other than to resolve a leak, I've never seen a recommendation to bypass a squarebody heater core.  They are usually continuous flow (always have water running through ), so there isn't much of anything to fail except to start leaking.
One very common heater problem is that a lot of junk falls down the defroster vent and ends up in the plenum behind the glove compartment.  If you remove the glove compartment door you can access the screws that hold the panel on the heater plenum right behind the glove compartment.  Then you can see the blend door, move the controls to make sure it goes full travel, and pull out the pens, pencils, matchbooks, parts receipts and other junk that has fallen down there.  You might even find remnants of a mouse nest they made from the fluffy insulation on the firewall.
Bruce
