Author Topic: New to forum Help decode build sheet old moving van  (Read 6317 times)
Offline macleay1
« on: June 20, 2019, 09:54:19 am »
Hi
Need help decoding the build sheets. Getting ready to buy this old moving van to turn into a car hauler. Its parked against a fence and can't open the driver door.
Need to know what year it is.
Size of engine and horse power.
And are there any good options listed.
Thanks
Offline Rapid Roy
  • Euless, Texas
Re: New to forum Help decode build sheet old moving van
« Reply #1 on: June 20, 2019, 11:08:30 am »
Welcome
Mopar by Birth
Chevy by Choice
« Reply #2 on: June 20, 2019, 12:29:37 pm »
you can tall most of that from the vin
http://73-87chevytrucks.com/VIN.htm
lets start with this isnt a typical truck (or maybe the glove box was switched)
the rpo sticker came off a GMC INCOMPLETE truck
WITH 16001-19500 brakes
6000 med duty truck
4x2
and a 6.0 4 bbl gas motor
the tenth digit is the year, yours appears to be an 1988
Offline bd
« Reply #3 on: June 20, 2019, 12:31:04 pm »
1 G D E 6 D 1 B 4 J V 525218
Based on the VIN and SPID label, the truck is a US built, 1988, incomplete C6500 medium-duty conventional cab GMC, 2-axle chassis with 16001-19500 lbs GVWR hydraulic brakes, 6.0L (366) V8 gas engine protected by an alarm/shutdown system and fueled by a governed 4bbl Holley carburetor drawing from a 50-gallon right-mounted step-tank.  The engine pushes power through a 13" Spicer clutch and Spicer CM-4054A 5-speed transmission along a 3-piece driveline to a Spicer final drive with 5.29 gears.
Offline macleay1
« Reply #4 on: June 20, 2019, 01:15:44 pm »
Thanks for the reply's. Just noticed I posted the same pic twice. Here's the other.
« Reply #5 on: June 20, 2019, 07:02:40 pm »
looks like the same one
Offline macleay1
« Reply #6 on: June 20, 2019, 07:21:43 pm »
Same one?
Offline fitz
« Reply #7 on: June 20, 2019, 08:47:12 pm »
Welcome to the site.
Looks like Irish & BD solved the problem once again.
I have a few "incomplete" trucks myself.  Someday hopefully I'll have time to put them back together.
« Reply #8 on: June 21, 2019, 01:08:28 am »
same vin just a messed up picture.
Offline bd
« Reply #9 on: June 21, 2019, 08:17:07 am »
Like a new Harley... the quintessential perpetual project....
