Author Topic: Uninstall Old Trailer Brake Controller  (Read 8035 times)
Offline jsc
« on: July 30, 2019, 06:25:48 am »
When I bought my '83 C10 4 years ago, it came with (what looks to be) a Kelsey Hays trailer brake controller. Funny thing is, I don't even have a trailer hitch, and I don't think I'll EVER have need of trailer brakes.
So how can I uninstall it?
Thanks!!
John
Re: Uninstall Old Trailer Brake Controller
« Reply #1 on: July 30, 2019, 08:57:39 am »
If it is all electronic just cut the wires and take it out.  If it is the one that hooks in the fluid line you just take it out.  If you don't touch the brake pedal you shouldn't have to bleed the brakes.
Offline jsc
« Reply #2 on: July 30, 2019, 05:42:38 pm »
Will I need to plug the master cylinder?
« Reply #3 on: July 30, 2019, 05:55:46 pm »
The ones I have seen uses a T style fitting.  The straight through (top of the T) is the same threads.  You can take that T out and hook the brake line back up to the master.  Post a picture and I can tell you for sure.
Offline jsc
« Reply #4 on: July 31, 2019, 08:48:02 am »
Here's my master cylinder.  I'm guessing the trailer brake fitting is the bottom one?  It looks like I need to remove the entire "T" and then put brake line back in.
Thanks
John
« Reply #5 on: July 31, 2019, 09:39:11 am »
Thanks
John
Yes that is it.
Offline JohnnyPopper
  • Old Goof
« Reply #6 on: July 31, 2019, 01:25:50 pm »
That's a pretty clean motor compared to some I've seen on this site!
1980 C-10 under construction
Offline jsc
« Reply #7 on: July 31, 2019, 02:28:18 pm »
I bought it with a bad engine.  First thing I had to do was install Crate 350.  Then wheels and tires.  Then...  Well, you get the picture.
