Author Topic: Mystery Brake Linkage  (Read 5213 times)
Offline JohnnyPopper
  • Old Goof
« on: August 31, 2019, 05:48:47 pm »
So I'm under the C-30 and see a device that the rear brake line goes into before it splits to the two wheels.
It has a cylindrical body where a lever is attached at the center.
The lever is then connected to 90 degree arm that is fixed on the body of the axle.
I can only figure that it reacts to the rear axle flexing upon a heavy brake.
But what does it do?
It doesn't look sophisticated enough to be an anti lock system, but I could be wrong.
Any ideas? Thanks!
1980 C-10 under construction
Offline bd
Re: Mystery Brake Linkage
« Reply #1 on: August 31, 2019, 06:11:15 pm »
Scroll down to Reply #3, Height Sensing Proportioning Valve.
  • Old Goof
« Reply #2 on: September 01, 2019, 12:47:59 pm »
BD you're the man!
And thanks to VZ for putting that together!
Offline roundhouse
« Reply #3 on: September 03, 2019, 07:53:25 am »
Primitive anti lock
I’ve bypassed em in just about every vehicle cause they never work right
