Author Topic: ignition buzzer  (Read 6655 times)
Offline rodwood
ignition buzzer
« on: September 20, 2019, 11:12:30 am »
I can't figure this out, my key buzzer always worked like this. Function 1  turn ignition on buzzer sounds for a few seconds with the seat belt light, this function still works, function 2  turn ignition off and open door buzzer sounds and reminds you the key is in the ignition this function has changed and works like this turn key off buzzer sounds with door closed. What has changed is the installation of a Dakota Digital dash where I took the seat belt warning light wire and moved it to the Dakota control box, but I don't see how that can effect the original function that would sound the buzzer as soon as the key is off with door closed,  I also installed a cruise control and routed the control cables down the inside of the steering column of coarse to do this I had to disassemble the column including the ignition could I have done something during the column reassemble that would change the buzzer from sounding when the door opens to sounding as soon as key is off??
Offline rodwood
Re: ignition buzzer
« Reply #1 on: September 20, 2019, 11:17:21 am »
So sorry my truck is a 1986 C 10
Offline Rapid Roy
  • Euless, Texas
Re: ignition buzzer
« Reply #2 on: September 20, 2019, 11:26:29 am »
Welcome to the site.
Mopar by Birth
Chevy by Choice
Re: ignition buzzer
« Reply #3 on: September 20, 2019, 11:29:40 am »
Check the function of the dual contact door jamb switch.  It sounds like the tan wire from the steering column key warning switch may be constantly grounded.
Offline rodwood
Re: ignition buzzer
« Reply #4 on: September 20, 2019, 03:51:48 pm »
Thanks bd could I have accidently grounded during reassembly?
Re: ignition buzzer
« Reply #5 on: September 20, 2019, 05:22:10 pm »
yes
Offline rodwood
Re: ignition buzzer
« Reply #6 on: September 20, 2019, 06:26:59 pm »
Thanks, I think I know where to start
 Problems are linked to where I have been...
