Author Topic: 73-87 big block WATER PUMP install videos/instructions  (Read 3273 times)
Offline sammysamm
« on: September 23, 2019, 09:00:15 pm »
Hey,  you guys have all been a big help in past.
Im looking for a video or link  to step by step instructions (pdf) for replacing my water pump on a 454 big block 73-87 chevy c20 camper special. everything is stock .
i see a lot of you tube videos for c10 350 small blocks online but i dont see any 454 big block videos.
can someone post a link to a video or a mechanics manual for a replacement of the water pump?
would be lots of help as i learn better from video than anything.
i have done basic maintenance like replace alternator and starter in the past as well as belts changed. im hoping i can do this myself without any problems. let me know if i will need any special tools etc.
i noticed it says to tighten all bolts to 30lbs torque..
thanks
Re: 73-87 big block WATER PUMP install videos/instructions
« Reply #1 on: September 23, 2019, 09:03:22 pm »
should be the same except for the PS reservoir if equipped.
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: September 24, 2019, 01:17:51 pm »
Dive in! Go with your gut man! You can do it!  ;)
1980 C-10 under construction
