Author Topic: Tbi or not  (Read 8792 times)
Offline johndeeregreg4
Tbi or not
« on: November 01, 2019, 01:51:45 pm »
[IMG]https://uploads.tapatalk-cdn.com/20191101/1eb4e67ff7f7e56fb80d52512be84b50.
Trying to get some clarification on the type of 350 I have in my K10. Bought this truck about a year ago and do not know what this engine came out of as it’s a swap done 2 owners ago.
Thanks!
-Greg L.
Re: Tbi or not
« Reply #1 on: November 01, 2019, 02:11:35 pm »
What are you attempting to link?  Images can be attached using the "Attachments and other options" line located below the text window while posting.
What year is the vehicle?
Re: Tbi or not
« Reply #2 on: November 01, 2019, 02:26:07 pm »
I’m trying to post a picture of the engine sorry I thought it worked the first time!
Re: Tbi or not
« Reply #3 on: November 01, 2019, 02:27:04 pm »
What are some things I should look for to distinguish a tbi vs non tbi 350?
Re: Tbi or not
« Reply #4 on: November 01, 2019, 08:07:20 pm »
a tbi unit will be on top of the engine.... but the center bolt valve covers are usually a giveaway
Offline Stewart G Griffin
Re: Tbi or not
« Reply #5 on: November 04, 2019, 09:10:25 am »
What type of fuel pump you got?    And where is it located?
Offline SlayTank
Re: Tbi or not
« Reply #6 on: November 17, 2019, 09:50:28 pm »
From what I looked around at states The TBI heads have the center bolts for the valve covers and the two center bolts on ether side of the intake go in at a different (more straight up and down) angle. Those look like TBI heads and thus TBI intake. It could be a carb on top if someone swapped it out.
Offline 75gmck25
Re: Tbi or not
« Reply #7 on: November 18, 2019, 05:51:28 am »
Based on the centerbolt valve covers, it appears to have TBI heads.  However, based on the linkage visible, it also appears to have a carburetor.
TBI (throttle body fuel injection)
- 87-94 TBI heads with center bolt valve covers (uses TBI intake manifold)
- throttle body mounted in the center of the intake manifold (not a carburetor)
- in-tank electric fuel pump
- computer and sensors to run TBI
Carburetor
-  55-86 style cylinder heads (old intake manifold bolt pattern)
- perimeter valve cover bolts (bolts down the edge of the valve covers)
- 4 barrel carb mounted in the center of the intake manifold. Stock was a Quadrajet, but Edelbrock and Holley are often installed.
- Mechanical fuel pump mounted on passenger side, lower front of engine block.  Metal line running up to carburetor
- No computer
Bruce
Offline Shifty
  • I bleed Bowtie red...
Re: Tbi or not
« Reply #8 on: November 18, 2019, 09:08:48 am »
I've seen it an awful lot where people didn't fix a TBI problem, and ended up just changing out the intake and putting a carb on instead.   Heck, I've even see hillbillys replace the electronic distributor for points simply because they just didn't trust them dancy 'lectronics.... :o
98 C2500 ext cab longbed
Re: Tbi or not
« Reply #9 on: November 18, 2019, 01:26:32 pm »
you can make a carb intake fit the tbi heads and theres prob a intake you can buy for the carb to go to tbi heads.
